1 - 2 of 2 Posts
I searched on here as well as read the manual. The manual isn't too clear. But, how do you remove the electrical connector from the headlight bulb? Do you just forcefully pull them out? I know that you rotate the ring counter clockwise, but just disconnecting it from the connection has got me stumped.
theres a clip on it, hard to explain in words, but it looks like a clip ??? i suck at this. its black, with wires coming out of it, little tab on the top that you squeeze...
just squeeze the clip and pull away from the light. it may take a little wiggiling but it should come right off. if it doesnt, then you are not squeezing hard enough, but dont squeeze to hard cuz you can break the connector.
1 - 2 of 2 Posts
