So, Im researching different headlight assemblies, and found these black bezeled tinted ones that look IDENTICAL to the ones I have in my 2011 Pro-4X...however in the description it says this...
Correct for S or X Models only
Not correct for SE, SV, Offroad, or Pro-4X Models
How is this possible????? I looked at the wiring harness and mounting points and they are the same!.... it says for 2005-2015 further in the description
My 2011 Pro 4x just hit 205K! It has been very reliable so far...due in part to a pretty good maintenance schedule all its life. All the fluids(engine, trans, diffs, transfer case, brake, power steering, coolant) and air filter have been routinely changed. It has newer drive belts, battery...
2011 PRO4X----If I raise the front 2" with new bilstein 5100 adjustable struts and the rear with new heavy duty leafsprings, AND use 1 1/2 wheel spacers will the 285s fit easily without the melt mod?
Thanks!
Kevin in NH
So i have a Nisstec 1.5 lift.. With lower cam bolts. No UCA, just stock. Went to get alignment came back to specs but my passenger side still looks to have positive camber visually. What's wrong here? Thank you in advance
Getting hot on the mods already. :)
Just interior for right now, but these were top priority.
Friday I ordered my ScanGaugeII w/ Blendmount. (paid $179 for the same package last year, $206 is how much they cost now! :( )
And a few minutes ago, I got the rear cargo barrier from Raingler...
Hi everyone - Am i missing something here, my new to me 2011 xterra pro4x airbox to fender pipe has a gap on the end so though there is foam there it effectively does nothing not touching so it doesn't separate the air from the engine bay from the fender. I will at some point try and get a...
