the tire warehousewillgr1 said:what tire store? i always get my tires done at NTB and get the road hazard warrenty, they will replace it if any damage from the road occurs, regardless if the tires are over inflated (or atleast that's been my experience).
I had them inflated to 40 PSI, I know that is the max, but doesnt seem that it is too excessive.usmc xterra said:Yea you ran over something and as sharp as it was, you'd a never felt that. I also agree they were run overinflated, Air up your tires about 5 PSI over the spec, before you stop for the day, then air them down to spec beginning of next day, that will keep the stupid tire sensors from going off and be right on as far as PSI. Every time we have a major temp change, it has to be done again. Mostly when it gets colder. MC
all were slightly more worn in the middle, and as for the nitrogen in the tires,muzikman said:I agree that N2 is better than any other gas in a tire, but damn, $27? That seems a bit steep for a bit of N2.
Go to a welding shop and see how much a 3000spi bulk tank of N2 costs? You can fill quite a few tires.
As for over inflated. 40psi might not seem high, but because of the center wear, I would say they were way over inflated. Are all the tires worn like that?
