1 - 6 of 6 Posts
Are you sure it isn't your drain plug that is leaking? Might be worth to check if you haven't - may just need tightened.
I usually try to shy away from the cheapest part available, unless I am really on a budget. All the radiators could very well be the same quality.
These are all the options: Link
When I replaced my radiator I think I went with the Koyo on the 2nd page. In my head it was higher quality than the others, and also not $300... does that make me a brainwashed consumer that directly correlates price with quality? Probably a little bit. I guess it depends on how much you want to spend.
Griffin makes a radiator for the X now for $500+...
Good idea to check!
But there's coolant all along the the plastic portion of the rad with the drip localized to the opposite side of the drain.
I may pull the rad to inspect further before replacing, though I may as well just avoid the dreaded SMOD and install a replacement while I've got it out.
Thanks for the link NOAH.
I agree that the cheapest parts usually make me a bit nervous. I'll take your advice and look for a happy medium.
Thanks
Check your hoses too. Most people that I know of who have replaced them go with the Koyo model A2807. To my knowledge, this model uses slightly different internals so SMOD would not be an issue with it.
1 - 6 of 6 Posts
