1 - 5 of 5 Posts
Ok, so I bought a second hand brush guard (and before you give me hell for buying a brush guard, it was a steal and it's mostly for looks). HW is not included. I found the install instructions online and went to McMaster Carr to buy the HW. Here is the list (and costs):
Line Quantity Product Ships Unit price Total Delete
1
pack
91180A720
Metric 8.8 Zinc-Plated Steel Hex Head Cap Screw M12 Size, 40 mm Length, 1.25 mm Pitch, Fully Threaded, packs of 10
today $6.67 pack 6.67
2
pack
91280A718
Metric 8.8 Zinc-Plated Steel Hex Head Cap Screw M12 Size, 35mm Length, 1.75mm Pitch, Fully Threaded, packs of 25
today 12.28 pack 12.28
3
pack
91100A180
Metric Zinc-Plated Steel Large-Diameter Flat Washer M12 Screw Size, 37mm OD, 2.7mm-3.3mm Thick, packs of 25
today 7.63 pack 7.63
4
pack
91202A246
Metric Zinc-Plated Steel Split Lock Washer M12 Screw Size, 21.1mm OD, 2.35mm min Thick, packs of 100
today
(from our New Jersey warehouse)
Need this sooner?
8.06 pack 8.06
5
pack
90591A181
Metric Zinc-Plated Steel Hex Nut Class 8, M12 Size, 1.75mm Pitch, 19mm Width, 10mm Height, packs of 50
today 8.60 pack 8.60
6
pack
92095A244
Metric 18-8 Stainless Steel Button Head Socket Cap Screw M6 Size, 30 mm Length, 1 mm Pitch, packs of 25
today 8.31 pack 8.31
7
pack
95211A160
Metric Type 316 Stainless Steel Large-Diameter Flat Washer M6 Screw Size, 18mm OD, 1.4mm-1.8mm Thick, packs of 25
today 7.74 pack 7.74
8
pack
91202A234
Metric Zinc-Plated Steel Split Lock Washer M6 Screw Size, 11.8mm OD, 1.5mm min Thick, packs of 100
today 2.84 pack 2.84
9
add item to your orderview help for placing your orderPaste products and quantities
Merchandise total
$62.13
IMHO this is a nuts (pun intended) amount of money to spend on bolts and washers and the like. Does anybody know a website where I can buy these piece by piece instead of in packs? Are these particular parts common enough to be stocked at Home Depot?
Thanks for your help!
Doubt it. My local Ace has a good stock of metric, but for specialty stuff I like BoltDepot.com - they happen to be located in Weymouth! You can order individually and have it shipped, or since you're in the neighborhood you can go pick it up (counter service only, so you can't just go in and pick through their stock).
I'll check them out. Thanks!
Update: Bolt Depot had everything I wanted, with spares, for $24 and change.
I'll be posting pics when this phase of the build is complete. I have some stealthing, some wiring, and a bunch of wrenching to do.
1 - 5 of 5 Posts
