1 - 20 of 342 Posts
Many more details, mods, and pics still to come...Thanks a lot for viewing.
Username: GuerrillaXT
Vehicle Name: EXODUS
Year: 2010
Trim: Off Road/Titan Swap
Color: Night Armor
Mileage:
67,800
Ride Height Specs:
Front Fenders - 41.50"
Rear Fenders - 42.00"
Present Day:
Other Pics:
MODIFICATIONS
SUSPENSION/BRAKES/TIRES
Front:
  • Sway-A-Way 2.5" Remote Reservoir Coilovers
  • PRG Titan Upper Control Arms
  • OEM Titan Lower Control Arms
  • MOOG Lower Ball Joints
  • MOOG Titan Inner + Outer Tie Rods
  • Timbren Bump Stops
Rear:
  • Alcan Springs w/ 3" Lift + 475 lbs. Load Capcity
  • Radflo 2.0" Emulsion Rear Shocks
  • PRG Variable Height Shackles (Middle Setting)
  • PRG U-Bolt Flip Kit + 3 Degree Shims
  • Wheel Adapter 1.5" Wheel Spacers
Brakes:
  • Power Stop Evolution Sport Rotors
  • Power Stop Evolution Sport Brake Pads
  • PRG Extended SS Brake Lines - Front
  • AC Extended SS Brake Lines - Rear
  • Raybestos E-Brake Shoes
Tires:
  • 285/75/R16 Toyo Open Country A/TII XT (5)
POWERTRAIN/DRIVELINE
  • Titan M205 w/ 4.10 Gears + ARB Air Locker
  • Titan CV Axle Shafts
  • Xterra M226 w/ 4.10 Gears + ARB Air Locker
  • Eastern Catalytic Primary + Secondary Catalytic Converters
  • Dynomax Ultra Flo Welded Cat-Back Exhaust
ARMOR
  • Hefty Fabworks Front Bumper (Original Design)
  • MaX Gear Tire Carrier Rear Bumper 2.0
  • Hefty Fabworks Rock Sliders
  • Hefty Fabworks Radiator Skid Plate
  • Hefty Fabworks Engine Skid Plate
  • Hefty Fabworks Transfer Case Skid Plate
  • Hefty Fabworks Transmission Skid Plate
  • Hefty Fabworks Gas Tank Skid Plate
  • Blue Torch Fabworks Rear Diff Cover w/High Fill
AUDIO/ELECTRICAL
  • Odyssey PC1500RT Deep Cycle Battery
  • Marine Brass Battery Terminals
  • Cobra 29LX CB Radio w/ 4" Firestik Antenna
  • Pioneer 4300 DVD Head Unit w/ 7" Touch Screen + Bluetooth
  • Pioneer D Series Speakers
  • JBL GT018T Grand Touring Series Tweeters
  • Audiovox CMOS2 Forward Facing Camera
  • Rydeen Universal MINy Back Up Camera
  • PIAA Sports Horns (500-600 mHz)
LIGHTING
  • HIDProjectors Custom HID Retrofit Headlights
  • Sylvania ZXE Halogen Fog Lights
  • Aurora 40" LED Roof Light Bar
  • Aurora 20" LED Bumper Light Bar
  • Rigid Industries SR-M LED Diffused Side Lights
  • Rigid Industries Dually LED Reverse Lights
  • 18" LED Strip Wheel Well Rock Lights
  • Blue LED Interior Ambient Lighting (Front/Rear Seats)
  • V-LED Interior Dome Lights (Front, Rear, Cargo)
  • JLC Super Bright LED Reverse Lights
  • LED Reverse Lights in MaX Gear Rear Bumper 2.0
  • OTTRATW LED Rocker Switches
INTERIOR
  • Nissan All-Weather Floor Mats
  • Cover King MOLLE Tactical Seat Covers
  • Raingler RIXN Cargo Area Ceiling Net
  • WeatherTech Cargo Area Liner
  • ProClip USA Rotating Phone Mount
  • Netami Gas & Brake Pedal Covers
EXTERIOR
  • Hep's Designs Low Profile Roof Rack w/ Raingler Rack Handles
  • Bedlined Hood w/ Custom "XT" Stencil Design
  • Bedlined Gas Cap w/ Custom "XT" Stencil Design
  • Bedlined Rocker Panels + Rear Quarter Panels
  • Nissan Side-Window Deflectors
  • 35% Tinted Front Windows + Windshield Strip
  • Craven Speed Stubby Antenna
  • Stealthed/Tinted Tail Lights
  • Gobi Ladder w/ Grip Tape (Passenger Side)
RECOVERY/TRAIL GEAR
  • Warn M8000 Winch w/ Steel Cable + Wireless Remote
  • 4 D-Ring Recovery Shackles (2 Front, 2 Rear)
  • Hi-Lift 48" XTREME Trail Jack
  • Hi-Lift Lift Mate & Bumper Lift
  • ARB Snatch Strap
  • ARB Tree Saver Strap
  • Ratchet X 14' Ratchet Straps
  • Folding Military Shovel
  • Tactical/Hunting Knives
  • Xterra First Aid Kit
  • 1/4", 3/8", 1/2" Socket Set
  • Jumper Cables
  • Mini Maglite PRO LED Flashlight
MISCELLANEOUS
  • Bosch Icon Wiper Blades (20A, 24A)
  • Trico Exact Fit Rear Wiper Blade (14B)
  • Southco Locking Wetbox Handle
  • McMaster-Carr 175lb Rear Hatch Struts
  • ARB Rear Diff Breather Extension
  • Front/Rear Suspension Components POR-15'd
  • Heavy Duty Rear Tie-Downs
  • Femco No Spill Oil Drain Valve
FLUIDS
  • Engine Oil - AMSOIL Signature Series 5W-30
  • Engine Oil Filter - Nissan OEM Filter
  • Engine Coolant - Nissan Long Life Coolant
  • Transmission (Auto) - Nissan Matic-S ATF
  • Transfer Case - AMSOIL Multi-Vehicle Synthetic ATF
  • Front Diff (M205) - AMSOIL Severe Gear 75W-90
  • Rear Diff (M226) - AMSOIL Severe Gear 75W-140
  • Power Steering - Nissan Power Steering Fluid
  • Brakes - AMSOIL High Performance DOT 3
Garden Of The Gods. Rampart Range Road. Colorado Springs
Some Wheelin Pics:
Right After The Titan Swap:
Xterra Achievement Points: 661
Actually this is a pretty good build so far ~ I like it and keep on trucking!!
Needs more lights....
kidding. Nice job!
Mounted my Military Shovel and Hatchet/Hammer to the inside of the Hatch with Quickfist Mounts.
EDIT: Due to there being too much weight on the panel and it popping out when I closed the Hatch, I have since replaced the panel and it is back to the way it came from the factory.
Had a very decent past week or so. Finally installed my Shrock Rear Diff Cover.
Here's the How-to I wrote up on it: http://www.thenewx.org/forum/showthread.php?t=51836
And my Uncle, a Mechanic of 25 years, helped me install my DT Short Tube Headers I had laying around, can't say I'd want to have to do that again..
EDIT: DT Headers removed and replaced with OEM Nissan Headers. Refer to > Post #203
Did my Muffler. Went with a Magnaflow 12580 Dual-in Single-out. Sounds awesome in combination with the intake, IMS, and Shorty Headers.
BEFORE:
AFTER:
EDIT: Exhaust has been re-done since this post. Refer to > Post #203
Nice X!
Discussion Starter · #15 ·
1 - 20 of 342 Posts
