1 - 5 of 5 Posts
Intro Comments: Caught the mod bug from this site, build thread in progress, slowly continuing to mod; I am mostly aiming for an "Overlanding" build. I don't usually wheel for wheeling's sake, but rather to get to rugged, beautiful, and remote places. Will update periodically.
Username: GeolJon
Xterra's Nickname: Haven't figured one out yet
Year: 2011
Trim: Pro-4X
Color: Avalanche White
Powertrain/engine:
"Air Box Mod";
AEM Dryflow Reusable Air Filter, (switched from K&N after having to replace the MAF Sensor twice) - (Jul 2017);
XTP IMS;
Moroso 85474 Oil Catch Can - (Oct 2017);
Odyssey Extreme AGM Battery 34R-PC1500T w/Group 34 Spacer & Offroadgorilla Battery Hold-down;
BullyDog Platinum Tuner - (Sept 2017);
Dual Hood Struts (eBay);
Rear differential breather mod;
Radflo 2.0 Extended Coilovers 600 lbs/in;
Radflo remote reservoir piggyback shocks, 22.5" extended length - (Feb 2019);
PRG 2.0 UCAs;
Wheeler's Superbumps on LCAs;
Rear Timbren Active OffRoad Bumpstops - (Jun 2016);
Removed Rear Sway Bar;
MOOG Cam Bolts on LCAs;
PRG billet sway bar mounts and poly bushings;
Superpro poly bushings for rear leafs and shackles;
Superpro poly bushings for steering rack;
PREVIOUSLY
PRG 2" Front Spacer + DAAL & U-bolt Flip Kit - (Sept 2017);
Bilstein 5100 rear shocks (2-3" lift);
Armor/Protection:
Herculined Bottom Rocker Panels - (June 2015);
maXTERRA Rear Bumper w/Integrated Tow Hitch, (No Tire Carrier);
White Knuckle Sliders DOM, Herculined topside - (Feb 2017);
ARB Rear Differential Cover, black - (Mar 2017);
Rear Shock Skids, (InSain Fab? Sold by NissTec);
Tires:
BFGoodrich All Terrain TA/KO2s @ 285/75/R16 + Full-size Spare Mounted on a matching Pro-4X Alloy Rim;
Melt Mod;
Nilight 18W LED Flood Lights in Rear Bumper Corners with Auto/Off/On Switch on Dash - (June 2017);
Upsized Wiper Blades, (VALEO Ultimate), to 20/24" in Front, 16B in Back, w/added Stiffer Spring - (Jul 2015);
Rear Differential Breather Mod;
Southco Locking Handle on Roof Box (TNX group buy) - (Apr 2016);
Rubber strips on roof;
Front recovery points (ZackAttack MPS) with 5 ton WLL CM alloy d-shackles;
Nissan Rubber Floor Mats;
2.5 lb ABC Fire Extinguisher Mounted in Right Rear Cargo Area;
GenTech Autodim Rear View Mirror w/Compass & Outside Thermometer;
LED Map, Dome, (SMF6), and Cargo (SMD12), "Warm White" Lights from DiodeDynamics;
McMaster-Carr 150lb rear hatch struts;
Raingler MIXN rear ceiling storage net;
Raingler headrest grab handles;
Sound deadening: Noico sound insulation foam + Dynamat Extreme applied to rear hatch;
Electronics:
Bussman 100A Circuit Breaker for AUX Fuse Box, - (Apr 2017);
Blue Sea 6-circuit Fuse Box modded for Switched/Unswitched Power - (Apr 2017);
Garmin GPS Mount, Upgraded with Nuvi 2598LMTHD 5" Unit - (May 2017);
Garmin BC-30 wireless backup camera installed below 3rd brake light - (Mar 2019);
BullyDog Tuner Mounted under Center Console;
Handheld CB Dash Mount (TNX MPS) for Midland 75-822 Handheld CB Radio - (Jul 2017)
Lil Wil Mag Mount Antenna on Roof - (Sept 2017);
Equipment/Gear:
VIAIR 88P Air Compressor - (May 2015);
ARB Deflator - (May 2015);
Smittybuilt Tire Repair Kit;
ARB 50 QT Fridge/Freezer with Remote Wireless Monitor, ARB Power Socket installed at Base of C Pillar;
LED Mini-maglite Mounted under Center Console;
3D Maglite w/replacement LED permanently Mounted next to Rear Hatch;
Rotopax 2 Gal Water Container in Roof Box, 3 Gal Gas Tank on Roof - (Oct 2017);
42" Hi-lift Jack w/Off Road Base, JackMate Lift Accessory, Wheel Strap and Off-road Recovery Kit - (May 2015);
Hi-lift Handle Tools - (May 2015);
ProComp 20,000 lb WLL Recovery Strap 2"x30';
Tow Strap 5667 WLL, 17k lb Break Strength;
Scorpion Li-ion Jump Pack - (Jan 2017);
in the beginning
Where I started
Really Great Build Thread ! :D
1 - 5 of 5 Posts
