Hello everyone,
I've got a GNTX-453, good condition but I no longer have the Xterra. So I'm getting rid of some parts. It'll come with a temp sensor, wiring harness for the mirror, mirror itself, mounting arm and bracket. Amber LED will match the Xterra LEDs pretty well, this is similar to the Pathfinder spec mirror but includes the temp sensor. You'll need to splice in some wire for the temp sensor and the switched power, full-time power, and ground. Asking 200 shipped via Paypal. Slots right into the stock 2nd gen bracket with a set screw. The only things you'll need are a switched power connection, constant power connection, ground, and some wiring to connect the temp sensor up front.
