1 - 20 of 24 Posts
i have an '07 X with a tad bit over 14,xxx miles :albino: on it(seems like it was just yesterday when i drove it off the lot with 12 miles :cheers: on it) anyway my question is, is it too early to start using gas treatment additive? i prefer using lucas products if that makes any difference. thanks for any input............
I like the redline gas treatment. It isn't solvent based. Second would be the chevron techron in the black bottle.
I do an old racers trick to clean the car out. 100 Unleaded Octane burns very hot, hot enough to clean out the fuel system. About once every 3 months when gasoline is light, i'll throw 2-3 gallons of high octane in it.
I use Berrymans B-12 chemtool gas additive about every 3rd tank. Ive never had problems.
I'm sure there's new stuff out there; ie Techron.. But I've never had a problem w/ the Marvel Mystery stuff, mostly in imports.
I use the chevron stuff in the black bottle... I think this topic was raised about a year ago and someone said something about it..... I guess that is why i use it.
Once every 3000 miles.
Where do you get 100 octane?
You COULD buy 100 ll aviation fuel, but it is leaded (or has a lead substitute) and will hurt your catalyst. It is a cheap way to fuel supercharged hotrods by mixing with pump gas, but the whole idea of cleaning your engine with 100 octane does not make any sense from a technical standpoint- sounds like a bench racing wives tale. "it burns so hot-hot enough to clean out your fuel system"- it burns in the combustion chamber, not the fuel system...
secondly, these days municipal airports have fences around them post 911, so just driving up to a plane pump and swiping your card isn't so easy anymore.
Redline fuel additive is good- not solvent based so it won't release all the crap in your tank all at once to wreak havoc with your fuel system.
Inconsistantly varying the octane of fuel you use is not good for your vehicle in the long run. As a rule of thumb, it is ok to go up in octane, but after that do not go back down to the cheaper stuff. It can lead to engine and fuel system nuisances, and eventually problems. And I do not believe that additives are necessary unless you are at a major service interval or there is a problem.
I would agree with that last statement. Why are so many people using fuel additives? They shouldn't be needed in these trucks.
I used SeaFoam at 30k miles, but don't plan on using it again until about 60k miles, regularly using additives just seem like a waste of money.
My thoughts exactly every time one of these threads pops up. Applying a pound of cure to a problem that doesn't even exist, especially when using modern gasolines.
In fact, at the "recommended" treatment every 3k miles, I'd put my money on these things doing more harm than good. No matter how you slice it, concentrated solvents and hydrocarbon based lubricants - or even esther-based synthetics (like engine oil) don't play well together. I can only imagine how fast a concentrated dose of synthesized solvent destroys an oil's properties, even in the tiny amounts that gets past the rings. Not to mention the petroleum-based parts of the fuel system like O-rings, etc.
But, you guys knock yourself out. :blackeye:
save your cash on the stp, chevron, super cleaner stuff
Almost every manu. uses a product called BG44K to service fuel systems most dealers sell it and it is about 12 bucks.
When a dealer does an upper intake flush or fuel inj. service this is what they use
Bmw Mercedes, Volvo ford Gm Volkswagon porsche use this stuff for a reason it works
I will say i have heard good things about the seafoam
but when i spend my cash i want results
Almost every manu. uses a product called BG44K...
I just ran some of that through my wifes car today at the advice of a mechanic friend of mine. After about 35 miles the idle smoothed out and the throttle response was much crisper. I'll be running a bottle through my X at the next fill up.
Discussion Starter · #18 ·
Jerry, can you buy the BG44K locally? where? thanks, pat.
Hey Pat, I got it straight from the BG rep, but I heard that you can get it from:
Sports Haus Inc.
9732 S. Virginia Street
Reno NV US 89511
I'll try to get a hold of my friend and get the number of the BG rep. for you.
Discussion Starter · #20 ·
Sports Haus Inc.
Reno NV US 89511
that would be awesome...thanks.......
1 - 20 of 24 Posts
