1 - 3 of 3 Posts
I have looked at all the threads related to fuses, but I'm still at a loss here.
I was putting in some LED's last night and got in a hurry and shorted out inside one of the rear dome lights. I saw the spark and heard the fuse blow. My bad.
So I open the fuse box, find what I think is the offending fuse, and pull it out, sure enough it's blown, but when I look at the diagram and fuse block, things don't line up. See pics...
I'm wondering if the original owner had some of these replaced? The diagram doesn't show 4 15 amps in a row. It also only shows one 20 amp.
Which ones are spares?
Are my eyes just so bad I'm not seeing this right?
I figured out the beige plastic thing is a fuse puller, worked pretty well on those little buggers. What is that larger white plastic thingy?
Here's the diagram:
Thanks
You notice that the top left fuse and the two top right fuses stick it further? Those three are spares.
You da' man! Thanks
I had to clean my glasses and magnify that pic to see that!
1 - 3 of 3 Posts
