1 - 12 of 12 Posts
Hey guys,
Just wondering what your thoughts were on a HID full headlight replacement was? Ive seen many people go with the retrofit option and couldn't find any doing a full headlight replacement.
I was checking out this http://www.protuninglab.com/05nixtduhale.html
Seems like a better deal than going with the DIY retrofit since everything is already pre-installed and pretty much plug and play.
Just wondering if i'm missing anything here since it seems too good to be true lol. Also since I've seen most people go the DIY retrofit route.
Those are the same junk ones you get off ebay. Projectors have uneven light disperssal, hotspots, ricey leds, bad sealing (condensation issues) requires splicing of harness since it is using two bulbs (one for high one for low, OEM is one bulb)....
Gotcha, yeah I figured it was too good to be true. Guess I'm going with the DIY retrofit option. Thanks!
they are better than factory headlights with hid bulbs
but not as good as a full retrofit.
Mr. Deltaphi: lol
Have you ever posted a pic with your new setup lit up? Your little LED strip looks sick. Am inquisitive how they look with some electricity running through it.
Mr. Deltaphi: lol
well, no. i haven't. I never got around to hooking them up all the way with the proper PWM and resistors. then I got drunk one night and wanted to test them. I wired up the passenger side and burned out half of them.
I need to pull the lights back apart anyway to deal with the sticking solenoids in the projectors. I'll pull the leds strips out and redo them.
Ouch! The regrets after beer, keep at it man. I think they would look awesome as always on DRL.
here's a taste...
1 - 12 of 12 Posts
