1 - 20 of 36 Posts
The truck is gone and I am sell all the parts I had in my garage.
Will not ship. Pick up only.
Used Shrockwork engine, transmission, transfer case, and gas tank. $500 for complete set. Will not separate. No hardware.
2 set of IOCN coils. 1 is 11" use for 6 months and the other is 13" was never installed. $70
1 OEM front toe hook. $20
1 lower control arm cam bolt. $20
1 set of OEM leaf springs. $100
OEM all weather front floor mats $40
1 set of used PRG front spacers. $???. I believe this are the 1" spacer. I will to check.
2 new wire harness to rear locker. $20
1 stock tail pipe with chrome tip. $40
2 new tow hitch receiver $40
New front hub. $100[/B ]obi_krash
New m226 diff cover. $100
PRG spacers look like 2" (unless you have .5" thumbs - measure the thickness and multiply by two).
Any idea what the weight rating on the springs is?
the spacer are 2" thick.
I believe the 11" is 550 and the 13" is 650.
any chance I could get the part number on that hub? If it works with an 07 X I might have to drive up to you and grab that sucker.
SP450701
That's a m226 cover not a "200k" ;)
You may be right. I had a 2005 frontier with a m226 and 2005 with a 200k. All these parts have been setting in my garage your a little over 3 years and don't remember which I order it for.
I'm right as I just ran a GB on the m226 cover from ballistic fab; it's the same design for the dana44 but has 12 bolts instead of 10. The other axle you are referring to is a "c200k" that came in AT's and non offroad/pro4x/pretty much anything w/o a e locker that was AT. GLWS
Any idea of the spring rates on the coils ? Also if you do decide to ship and split the skods i realy could use the transfer skid. Dont need to box it up just drop it off ups or usps amd slap a lable on it . Thats how i received my shrock oil skid
same here if you get enough people who want the skids. Ill take the oil pan skid
Discussion Starter · #14 ·
Discussion Starter · #18 ·
Discussion Starter · #19 ·
I am dropping the price on the diff cover to $90.
It is a blue torch fab m226 diff cover. Never installed it.
1 - 20 of 36 Posts
