1 - 5 of 5 Posts
Finally an easy streamlined way to mount a 40" LED light bar on the roof of your Xterra!
Whether you want to get rid of those under powered OEM "offroad" lights or upgrade your rig with some serious lighting the GRRilla light bar mount is your solution.
* Easily installs in minutes
* Uses existing roof rack bolt locations, no holes to drill
* Locates the light bar as close to the air dam as possible, minimizing wind noise
* Made from thick 10 ga cold rolled steel
* Fully welded for maximum strength
* Fully powder coated flat textured black on top of a zinc primer
* Curved base follows the contour of your roof rack (helps prevent ripping out your roof's rivnuts)
* All new stainless steel mounting hardware included
* Installation instructions included
* Proudly designed and built in the USA
GRRilla Mount Price: $85 shipped
Mount price includes: a set of GRRilla mounts, stainless steel bolts, stainless steel washers, rubber washers, installation instructions and shipping within the 48 States.
To Order GRRilla Mounts:
Order directly through our website. Once you place your order email us through the website with your order number and screen name and we will apply your TNX discount.
Totron Dual Row Light Bar Package Deal :
(1) GRRilla mounts, Size: Dual-XL
(1) 40" Totron Straight DC Series Dual Row LED Light Bar, Combo Beam Pattern (Model: TLB3240), 19,200LM, 240W, CREE LEDs, IP67 waterproof rating 16.0A @12VDC, 1 Year Warranty
(1) Totron Plug and Play wiring harness, high amp (Model: THS-311-A14)
Package Price: $370 Shipped within the 48 States, Int'l shipping is available
To Order a GRRilla Light Bar Package:
Aurora D-Series 40" LED light bar mounted with GRRilla Mount size Dual
Discussion Starter #2
We are currently taking pre-orders for the the Totron Light Bar Package.
Your order will ship before the end of January.
Package Price: $385 Shipped within the 48 States, Int'l shipping is available
Order directly through my website. Once you place your order email us through the website with your order number and screen name and we will apply your TNX discount.
1 - 5 of 5 Posts
