1 - 17 of 17 Posts
More than likely you don’t but running a couple wires is not hard. If you look up directions for the mirrors from Nissan one of the connectors is prewired on the A pillar I believe. You just have to put a pin with a wire in the half of the connector that goes to the head liner. Check your fuse block in the glove box for a 10a fuse labeled mirror to see if it is.
Amber display 453 sold.
To answer a few common questions that have been PMed several times.
No, I do not have any with Homelink and a temperature display. If I find one it will be posted.
They are not difficult to hookup. Just need power and ground. You can hook it up with Homelink on all the time or on with ignition.
Both 313s are still available. Both the hidden displays are pending payment.
Both 313s still available. Also still have 1 of the 453 Hidden displays.
1 - 17 of 17 Posts
