1 - 17 of 17 Posts
Tired of the vibes. Gonna just do a prg 2.5" lift aal and put the stock shackle. Anyone would be interested in both?? I would do 150 plus will half the shipping cost. Theres not even 500 miles yet on them.
I already have a 3 degree shim in with fat side foward. I even had an 2010 frontier with a fabtech lift and couldnt cure the vibe. I just have bad luck. I had my shackles set at 1.5" and it was pretty bad. Dropping it to the 1" setting helped alot and the yoke end of the drive shaft went in a good amount. Because i drive in 30-3mph zones alot it is very irritating. I can punch the pedal and get past the vibes very easily but like i sed i drive in the vibe mph. Also after having a good load that dropped the rear 1", my vibes were completely gone. Asoon as the load is back in, same effect
Reason for selling is prgs will give atleast 2.5". And nisstecs is only 2 maybe less after settling. After having a good load in the truck it had no vibes and my rear lowered almost a full inch. Ill probably try just the nisstec aal but might make my rear lower then the front. I kno for a fact just an aal will not give vibes as my friends here have only aal and spacers. None of them tried shackles. I wish they made a .5" shackle. So please this is a feelers thread not a smart arse thread.
I kno for a fact just an aal will not give vibes as my friends here have only aal and spacers. . I wish they made a .5" shackle.
1. That's not true I had vibes when I installed an add a leaf, with 2° shims.
2. AC makes a shackle with a 1/2" slot.
No one was being a smart ass just trying to help.
Discussion Starter · #13 ·
Shackles are off.. Aal is staying on but in process of ordering 2" spacers so i can sell the extended radz with spc control arms also have extra bushings. Not even 500 miles on them. Asoon as they are for sale then i will post price and pictures, i want to make sure its off the truck before i put them up for sale. But 100% positive they will.
Discussion Starter · #15 ·
Shackles can probably fit in a flat rate. I can half the shipping. Just heads up, while having them set at the lowest setting the highest setting seemed to close a few mm's. Could probably just bend it back alittle. There is no knicks whats so ever. I guess i just torqued down alittle to much.
If they're officially for sale now, I'd be interested in buying your adjustable shackles. Where are you located?
1 - 17 of 17 Posts
