SO....I bought some of these projectors from a member on here, got them. Realized that doing what i wanted to do was over my head. After I took them apart and painted the inside flat black. I also just got a little promotion, so going to be working more and i just need to get rid of these asap.
Here is what they looked like before i got them:
http://www.amazon.com/Nissan-Xterra-Chrome-Projector-Headlights/dp/B005V9NFGQ
Here they are now:
http://imgur.com/i8jfbpn
http://imgur.com/twyhXQw
I did take out the middle part, sprayed them flat black after sanding the piss out of them. I also removed the crappy halos, and was going to replace them and pretty much do this to them:
http://www.thenewx.org/forum/showthread.php?t=56290&highlight=ebay+headlights
http://www.thenewx.org/forum/showthread.php?t=24052&highlight=ebay+headlights
Everything is included, wiring, the old halos, all screws are in, etc.
The exterior housing part is in pretty good shape.
Could be sanded/buffed out to be like brand new. Just has normal wear on the headlights.
Here is some more info taken from a previous thread on these things:
These use H1 bulbs in the high and low. A harness is needed for plug n play. You will need 2 9007 female ends to plug into the oem headlight harness...and 2 9006 male ends to plug into the h1/9006 new light harness. the 9007 will have 3 wires...9006 2 wires....wire them up, share the same ground...
Figured these would be a good start to some DIY projectors, since most of the harder work is already done since they have been taken apart, sanded, primed, and painted.
$100 OBO plus half for shipping, USPS Priority - I just need them gone
PM me or reply here
PS - as soon as Photobucket is back up i'll upload and post the pictures correctly. Thanks
Here they are now:
PM me or reply here
