1 - 4 of 4 Posts
Discussion Starter #1 (Edited by Moderator)
Make - Nissan
Year - 2006
Model - Xterra
Trim - S
Color – Lightning Silver
Mileage - 160,xxx (highway miles drives 150 miles / day)
location: North NJ (wayne,belleville,nutley,clifton area)
Suspension/Tires/Wheels:
- 4x 285/75/16 Goodyear MT/R Old style
- 4x 16x7 S rims Bedlinded
- PRG shackels
- Calmini 2" spacers
- Bilstein 5125 series rear shocks
- Rancho AALs
- Front HD bilsteins
- 2" wheel adapters
Powertrain/Drivetrain:
- K&N Cai
- Drilled slotted rotors
- extented solid brake line braket
Interior/Storage:
- WeatherTech Digital Fit Floorliners
- Lobo rack
- Cargo rug mod
- Ballistic front and rear seat covers
Electrical:
- 4x kc dayligthers driving and floor (not wired, all items to be wired included)
- 3 OTRATTW Switches
- pioneer Bluetooth head unit
- Retro key fob
- 4" led fog lights
- Hammered fenders
- In channel window deflectors
- Xoskel Lo Pro Light Cage (not wired yet)
- Bedlined hood, front rear bumper, and rockers
- Plasti diped emblems and kc covers
- Chubby antenna (its useless doesnt get good reception)
- 2" BL
- Factory side moldings
Armour:
- 2" BL White knuckles sliders rusty as hell needs painting
Lube:
- Amsoil all the way
Recovery:
- front factory tow hook
- rear tow with harness (installed 6/2014)
Removed:
- Flap
- Side step
- Rear sway bar
- Under tire carrier module
as of November last year ABS, VDC, slip off and 4x4 are not working due to either, solenoid, abs sensor, or just needs relay according to our forums, ebrake is weak and I have the pads, the windshield water fluid tank only can hold half and leaks near hose line easy fix. p0455 engine code pops on and off every once in a while.
-oem Nissan clutch replaced - 2013
-oem alternator replaced - 2012
-all fluids due at 180,000 miles (changing every 40k miles with amsoil)
-rear drive shaft and u joints replaced - 4/2014
-both front hub assemble replaced - 2013
-the x runs great little vibration around 60-65 miles, front suspension needs caster alignment and made my tires have uneven wear. drove to mt creek a lot in the winter, new paltz in spring/fall and new York safety track in the summer, down the shore and daily driver.
$7500 hit me up via text 862-368-33onezero
1 - 4 of 4 Posts
