1 - 9 of 9 Posts
Hey all,
So I was making a hard left hand turn, on pavement, and the front right wheel wheel made a "Clunk" sound. It sounded pretty solid but didn't make any noise for +600km after that. Now there is some other noise that it is making. I will post a video tonight.
Any ideas?
Cheers!
Did you just do a lift? Check if your lower shock bolts are hitting your sway bar. They'll catch, build up compression, then release making a pretty horrible sound (ask me how I know).
Lil more info? Mileage, year, off road much? Could be ball joint, wheel bearing, suspension bolt like others suggested. even possibly one of the cv shafts.
mine makes a steady clunk clunk when at low speeds driving my batty.. any ideas? front drivers side on a 4x4
That clunk sound is what I get on random turns now. It started last week when I replaced my sway bar bushings. I just bought new links to see if it's that? But it ended up being over torqued bushings.
Update: mine was a worn out U Joint . Quiet as can be now
1 - 9 of 9 Posts
