1 - 10 of 10 Posts
I'm cranky today, a spacer lift will get you to a "look" cheaply. If you want a lift with performance gains it will cost you more. I recommend a bunch of research time, then decide what your usage goals are, then look at kits/components to get there. After that ask specifics to help with your choice of where/how to spend your cash.
There is so much info here to consume, but it gets buried when people ask the same thing 50 times.
Ive had good results with the ebay lifts in the past. But you need to get the leaf and the shackle. separate they just dont work.
that being said. I USED to have those. do yourself the favor i wish i did myself and save up to do it right. hell even stay glued to this forum and find the best used parts. you wouldnt believe the kind of parts i have on my x and the little amount i spent.
Like you said earlier I am new and I am sorry for all the questions..... I just want to lift it enough to level it.... Or make it sit a little high in front.
1 - 10 of 10 Posts
