1 - 13 of 13 Posts
· on line
Well after inspection of my skid plates this weekend I noticed that one of the bolts holding on the front diff skid plate was loose. It appears that the welded bolt inside the X member broke.
Any ideas on how to get to this bolt?
· on line
The BP skids uses the 4 factory skid mounting bolts on the sway bar X-member. One of the 13MM bolts in the X-member must have broken off and I cannot tighten the nut and bolt that holds the skid in place.
In this pict I refer to 1 of the 2 middle ones.
· on line
Offroad said:
I used a 5/16" - 18 tap. Get the right drill for it.
Thanks.
What do you mean right drill? I have a 1/2" Dewalt 18V cordless and can also double as a hammer drill.
· on line
Discussion Starter · #10 ·
The nut broke free. I have no idea what offroad tapped into. I haven't looked. I was just thinking of trying to fish the nut out and weld a wire to the end of it.
· on line
If you can get one of those telescoping magnets from your local parts store. I have a couple in my tool box. If there's an opening that you can get into that will allow you to bring that nut out through then try that.
· on line
Are you sure the nut broke free? What happened to me is that the screw BP provided was a little smaller than the nut and it pulled the thread out. The screw was not broken and was free, not because the nut was free (although it felt like it was free) but because it had no thread.
1 - 13 of 13 Posts
