1 - 20 of 30 Posts
I have been looking into front bumpers. I was wanting to go plat front bumper from RLC, but then I saw the calmini prerunner and it is really nice. Other then them, and Insane and I think Maxterrs design who else makes them and what other design is out there. Do you have pics. I searched the forum and pages upon pages came up but they had nothing to do with it, and the front bumper thread most of the pics are dead links.
Yep, the Calmini pre-runner I had on my Frontier had welds that started rusting in less than a year. The rear had coating start coming off in 6 months.
I don't like rust. RLC it is. Thank you.
Buy whatever one you actually like and just order it raw, then powdercoat it locally. That's what I did with my Hefty because I like the bumper, but their powder coater sucks.
I've been taking to powdercoaters. What I'm learning is:
- Media blast with aluminum oxide to give the surface some "tooth" for succeeding coats to adhere to.
- For welded steel armor, media blast is preferred over iron/zinc phosphate treatment because the tooth is better for adhesion.
- First coat should be a zinc-rich primer (Cardinal and Tiger Drylac have them, others too).
- Second coat is your color.
- If you're concerned about UV/weather resistance (gloss/color retention) go with a "super durable" powder that has an AAMA 2604 rating.
- Super durable powders use a different resin. But impact resistance may be lower.
- Powders with hammered/textured finishes can be less durable than smooth finishes (based on industry standard impact testing). Depends on the brand powder (e.g. Cardinal).
- Some advocate a third coat (clear or color) if you need super corrosion resistance (i.e. near the ocean or salted roads).
- Third coats cost more and may result in a more brittle coating if the coater isn't careful with timing in the oven.
- Beware of low-cost coating where they don't do much prep work.
- Make lots of phone calls. You'll get quotes all over the map!
Finally, there are lots of opinions out there as to how to finish armor/bumpers (e.g. paint, powder, Line-X). Some powder vendors like Cardinal sell touch-up paint that matches their powders. Also seen anecdotal info ... you can repair minor cracks & scratches in the powder by using a heat gun (I have not verified truth behind this).
RockyMtnX is correct. I do have a 2" BL. Not too worried about the gap at the moment but at some point I'll get the mad scientists together and get it raised up
I agree, doesn't look horrible and the truck looks pretty mean! I wounder if you could simply copy the bumper raise brackets that are provided with a body lift for stock bumpers or at least that option was available from Nissan Parts kit.
1 - 20 of 30 Posts
