1 - 20 of 34 Posts
We put our Nisstec Ultimate lift kit (+OME HD leaf pack) today - it took over 6 hours despite using a car lift, air tools and 2-4 people working on it at times. The biggest problems?
1) couldn't find the lug nut key ([email protected]# you, Discount Tire for not putting it back)
2) couldn't get lower front shock bolt off on passenger side
3) couldn't get 2/4 shackle bolts off on the rear
On the front, we put a breaker bar to it and rounded the nut, and ended up having to drill it out. Found a spare bolt & nut, which I promptly broke trying to apply 155 ft. lbs. Luckily someone was able to get the right grade bolt & nut from a tractor supply store. The rear bolts required a heat gun, pipe wrench and breaker bar. And the lug nuts we took off by bashing a 3/4 socket onto them with a steel mallet and ratcheting off.
Lots of other minor difficulties, but those were the worst. So $&!# you too, Nissan for literally *coating* the bolts in some loctite like compound - and by coating, instead of one drop I mean 3-4 inches of the bolt was covered in this stuff.
great, sounds like I should start hitting the bolts with some PB blaster now and I haven't even ordered the leaf pack yet
Definitely. I hit everything up with some Valvoline lubricant I had the night before, and it didn't seem to help a ton.
Hit everything with Blaster everyday for about a week, especially as if your truck is older or in the salt belt.
Truck is only 2 years old. 12k miles.
Gravedgr,
Probably not what you want to hear but so far my 2011 has disassembled very nicely. I've changed out both bumpers and front and rear springs. I'll make a recommendation based on reading about your rounding bolts and using pipe wrenches and cheater bars. If you don't have a 2 sets (1 deep & 1 reg. length) of 6-pt 1/2" dr. impact sockets you should pick them up. 6-pts rarely round heads and work well with breaker or cheater bars. Good luck on your future mods. I will be knocking on wood now :icon_smile:
Scott
I have been putting acetone/atf mix on my bolts for about a month now, along with some PB blaster anticipating this head ache. I even wrench on things for a living and am worried about how bad these bolts could be seized up here in michigan,
It took 2 hours to install pre assembled front coil overs, rear shackles, and shocks with Toro.
Well, let's be honest....this TORO fella....well, he's the stuff of legends...
I heard once he swapped coilovers on a friends rig WITHOUT TAKING THE WHEELS OFF....
Rumor has it he sleeps 2min a night.....and installs cargo racks blindfolded with just his left foot!!!
1 - 20 of 34 Posts
