1 - 10 of 10 Posts
did a quick clip from the inside. its too windy right now to try and get the exterior but i'll see what i can do. i kept the over all quality down a little bit to save on bandwidth. turned on metallica - mercyful fate at volume 10 on a stock S stereo (non RF). i'll update once i get the exterior posted up as well!
got the stationary exterior clip. alittle higher quality...
Sounds nice man. Did you upgrade the stock y pipe with a 3 inch piping as well? So you used 3" piping from the cats all the way back?
Discussion Starter #7
no, its a factory y pipe. while i was in turkey i had a guy cut the muffler off in front , (you know, where nissan excelled at smashing the two pipe together) and then welded that to the new muffler. he then did 3" pipe in the factory routing, no clearance issues and all for 40 bucks! well..plus 90 for the muffler from summit :)
1 - 10 of 10 Posts
