Please don't reference the owners manual. I have read what it says about flat towing an XTerra.
We are considering selling our V8 4runner, and have our eyes on a local 2011 XTerra X because we really don't want a Jeep. (We used to have a 2010 X, but sold it a year ago. Bad planning I guess.) And we want to flat tow it behind our motorhome.
The only detailed thread, which was started by 00wabbit , concerns his MT 4WD X, which per the manual can be flat towed so long as you stop and run the engine every 500 miles.
It is my understanding that with a rear driveshaft disconnect installed we can flat tow a 4x4 Xterra with an automatic if the transfer case is in neutral. When we are flat towing:
a. With both the rear driveshaft disconnected and the transfer case in 2WD the output of the transmission would not be rotating, which would protect the transmission, but
b. The front driveshaft would be rotating the front output of the transfer case.
I am not getting a definitive answer of how well the transfer case would be lubricated when flat towing. The driveshaft disconnect guys say they have been used on Xterras, Frontiers, and Pathfinders.
Any thoughts here? I really don't want to buy a Jeep or other American 4x4 truck if I can avoid it..
The long story: We had a 2010 Xterra X automatic, and sold it for a 2007 V8 4Runner as that better suited our needs for our yearly cross country trips. Now we have a motorhome so our cross country trips can be months longer, but we wish to flat tow a 4x4 behind us. The V8 4Runner cannot be flat towed as it is all wheel drive unless I install driveshaft disconnects on both driveshafts. (Only the V6 4Runners have a 2WD mode in the transfer case.) The rear driveshaft with a driveshaft disconnect is not a big problem. The biggish problem is that I would have to engineer and build a custom front driveshaft that I may have to get custom machined parts for. Long lead times and many $$$$. So we are considering selling the 4Runner and moving back to an XTerra if we can flat tow it without damage.
