1 - 8 of 8 Posts
Hey.
So during this dreadful winter, when I use my key fob to unlock my car, the blinker lights used to flash. they no longer do.
When i lock my car the blinkers do flash, but there is no horn like there used to be.
I have checked my fuses, they all seemed good. is there something that could cause this that I am missing.
Thanks
Hey.
Thanks
You might have changed the setting by sitting on it. go to your X and hold both lock and unlock at the same time until the lights flash. it should go back to making noise.
I disabled mine the same way. i get home late and didn't want to bother anyone
Maybe a relay. When I bought mine (used) the horn didn't honk (at all) and I took it back to the dealer(I had checked all the fuses too). They ended up replacing a relay
I admit, this doesn't solve the flashing of the lights. The above post may be more likely, but if that doesn't work, maybe check the relays.
^^^this
Thank you for your help! i figured it was just the extreme cold and everything would fix itself…didn't happen, ends up i just sat on it wrong. whoops
Ahhh Yes, this question comes up every so offen a couple times a year, as noted below;
Anyone know how...
09-14-2007, 11:28 PM;
http://www.thenewx.org/forum/showthread.php?t=4746
keyless lock/unlock
01-06-2008, 09:28 PM ;
http://www.thenewx.org/forum/showthread.php?t=6413
Disabling "horn beep" when locking vehicle?
05-05-2008, 07:48 AM;
http://www.thenewx.org/forum/showthread.php?t=8933
Xterra not beeping when locked
09-28-2009, 11:23 AM;
http://www.thenewx.org/forum/showthread.php?t=21090
Horn now beeps when I lock the doors
03-13-2011, 09:19 PM;
http://www.thenewx.org/forum/showthread.php?t=40044
doesnt honk when locking
01-15-2012, 08:28 AM;
http://www.thenewx.org/forum/showthread.php?t=50172
No Locking Horn!!
09-16-2012, 12:10 PM;
http://www.thenewx.org/forum/showthread.php?t=58208
Key Fob/Hazard Light Question.....
01-17-2014, 04:59 AM;
http://www.thenewx.org/forum/showthread.php?t=85681
Just to list a few.....
1 - 8 of 8 Posts
