dragonplay YOU'VE Done it! By Gosh you are The man! YES! If what hey say is true Order it! I looked under flashers and they list a few and it says they will work with any LED regular bulb combo, I ope they also mean LED alone However, , considering that the front will remain incandescent, it should work anyways if they are on same circuit, in that case any electronic flasher will work. BUT for the price, I'd order that flasher and do the test, Take that flasher and note polarity of LED, an LED only works when + is on Pos side and Neg is on Neg side, Incandescent bulb it does not matter. Keep this in mind those of you working with LED's. Now, go bulb to neg, pos to flasher pole, and other flasher pole to + batt. If it flashes you have found the cure for all LED applications! First though, test it with a test light or regular bulb and get that to flash then hook LED respecting polarity. Remember one prong, normally the odd one out is just an indicator flip that trips the light on your dash when a bulb burns out. So don't use that one in the test. I use little jumper wires with alligator clips for this test. MC
