1 - 6 of 6 Posts
· Registered
2006 Nissan Xterra S RWD 6MT
Hi Gang!
I'm sure I'll get a lot of crap from some of you for this, but I got tired of that blinking TPMS light on my dash, so I "fixed it"!
I was opening up the instrument cluster to replace the broken off odometer reset stalk, so I got an idea to get rid of that annoying light in 2 seconds! Check it out:
· Registered
The only crap I'll give you is for linking to a video instead of saying, I stuck tape to the back of the instrument panel!
Thanks, Poston!
I have posted a different video, more entertaining. It's only 1 minute long, so shouldn't be too annoying.
· Registered
Just a heads up to everybody else. I had walmart automotive change mine. Paid $128 total (after washington tax) for 4 new sensors with metal valve stems installed and programmed. They are walmart brand, whatever that is. They work fine. Although if i am idling on some uneven ground, the light will flash. Not a traffic signal, but longer (5+ mins??) But will immediately go away after driving again.
· on line
Fixing TPMS is cheaper than not fixing it.
Several years ago I was towing a trailer. Mountains, curves, not the most wonderful towing trailer either. It was a bit wallowy going down the road but generally fine. TPMS light came on, pulled off at a rest area just ahead and took a look. Right rear tire picked up a bolt and was nearly flat. From the driver's seat you could not feel it. The trailer masked any low tire feeling.
If I had kept going a few more miles the tire would have come apart. There would have been accusations about a crap tire that blew out, which would have been false. The tire that was in perfect order when I left got a puncture. As it happened, the TPMS caught it and it was a simple patch job. If it was ignored and run flat, it would have destroyed sidewalls and cost a new tire. More than likely it would have come apart and when a tire comes apart there tends to be a fair bit of vehicle damage. Add in the potential of losing control, more vehicle damage, trailer damage, and even possible dead bodies.
Yes, I keep my TMPS functional. That one save has more than paid for the cost of maintaining the system.
So where do you find the value in not using the system?
· Registered
You are correct, your case proves that TPMS is rather useful feature when it works. In my case, I have about a 5 mile daily commute and did not want to spend the money to get new TPMS since I recently bought the truck and PO just replaced the tires last year. WHen it comes time to replace my tires, I will get new sensors and remove the tape. I just can't stand any lights on the dash. For 25 years I have drives older cars with out TPMS, and have never had any issues as I am disciplined in checking my tire pressure frequently.
Thank you for your response!
1 - 6 of 6 Posts
