Once a month, I will turn the key and get ONE CLICK. I turn the key again and it starts just like normal. The problem does not repeat again for 4-5 weeks. After 2 days of not driving the truck multimeter on battery shows 12.74. Zero corrasion from Odyssey AGM battery. All connections I checked are tight. This started 6-7 months ago and I replaced the IPDM with a black unit from salvage. Did not solve problem. 2007 S 4x4 with 249,400 miles. Starter is original. I thought I had replaced the cam/crank sensors 5-6 years ago but I can't find an entry for it in my maintenance log.
Am I wrong?
Cam/Crankshaft sensors, if they fail the truck will crank and crank but not start. Or, will start but run badly/low on power etc.
Battery/power cables, if they fail then the truck either turns over very slowly (dead battery), OR you turn the key and you get a series of rapid "clicking sounds" as the solenoid engages but when it tries to turn the starter motor there is not enough voltage so solenoid disengages, then engages again etc etc etc causing the "click click click" sound.
Starter, If it fails you get ONE click from the relay but nothing happens. But then why will mine go ahead and start when I try a second time?
That is my line of thought. I would appreciate you guys working the problem with me. This seems to come up regularly so I thought we could include all modes of failure in one thread for future members when it is their turn to figure out which of these failures they have.
Am I wrong?
