1 - 4 of 4 Posts
I know there are plenty of how tos about wiring up the locker to aftermarket switches, but I was wondering if anyone knew anything about wiring the factory locker switch into an S trim. Is the switch lighted? Which wires go to the locker module included on the offroad/pro4x trim? There are two larger wires and three smaller wires out of the switch.ight it be just a power and ground? And also, will I need a relay? Thanks.
Yeah, I know grounds get grounded, but I wonder if the lock indicator wire goes straight to the dash without any interruptions (relay, fuse). And I'm not sure which wire should be tapped into the 4lo harness.
Look for the thread on the locker by-pass, there was a wiring schematic, may help identify what you want in the stock harness.
1 - 4 of 4 Posts
