1 - 2 of 2 Posts
What is the size of the factory fog lights?
I found some 2.5 by 2.8 (oval shaped) for $60 and thought they might fit. I could measure the opening but figured one of you might have the answer.
I don't mind adding an extra switch if I can get the lights to fit and mount up decently.
Did anyone else put non-factory lights in their factory location? If so what did you put and how did you mount them.
TIA
The holes in the factory bumper (removed for Shrock front bumper install) for the fog lights are just a slight bit larger than 3 and 3/16 inches in diameter.
Of course the mounting location is larger than that.
1 - 2 of 2 Posts
