1 - 19 of 19 Posts
Just read through the whole thread.
The rear is a block, so that would not work with the X.
The Front from what I gathered is: "Steel Coilover shock Spacer system", relocation of LCA with a new cross member.
I should think the front should bolt up to the front of the X, though I'm not sure what performance/wheel travel gains you would get.
well, the front should work fine....
they list the lift only for 06 frontiers. why? because the test truck was an 06. will it work on an 05? sure. but they don't list it.
figure the front should work and get a custom leaf pack for the rear.
ahnyoungboi3 said:
y wont the rear work???? isn't it the same? blocks arent good but, it should still work.....
The X and Frontier have different rear suspensions. They have a SOA, we do not.
Nice to see options. The fronty guys really pushed hard on fabtech to have this made. You can always add radflow coilovers in the front.
Do they drop the diff.
I would be very hesitate to put 315/70/17's on our front diffs.
Now I know there is a fronty owner who is looking to have a D44 front IFS diff made to fit stock specs.
Discussion Starter · #18 ·
That's exactly what I'm doing, plus TC UCAs.
:thumbright:
1 - 19 of 19 Posts
