1 - 4 of 4 Posts
HELP!
Recently the outside rear door handle on my 2008 X stopped opening the door. It pulls, but the door does not open. Inside, the handle works fine.
That is, until I decided to monkey with it, and whilst trying everything, I switched the child safety switch and closed it.
Now, neither one works.
Suggestions?
Sounds like the cable was disconnected from the exterior handle inside the door. Because the child safety lock is now on my only suggestion would be to put the window all the way down and use a coat hanger to try to either grab the cable for the outside door, or disengage the child safety lock as I'm not sure if there is clearance to remove the interior door panel w/o the door being open...
1 - 4 of 4 Posts
