TLDR: Car wont start in cold or medium weather, battery is good, heat gun on ECM didn't help, only starts with a jump pack even after being driven for 2 hours+ and alternator charging battery.
-Gets a spark
-Has fuel pressure
-Requires a jump pack to start (even @50 degree weather)
-no problems once it actually turns over and starts
-battery is good
-alternator is probably good
-much harder to start in the cold (even with the jump pack)
Hey everyone! I've had my 2010 X 4wd (X trim) for about 4 years now and just had to get new tires so I finally decided to start building my truck out. With it I began to tackle problems I've had with it over the past few years and never really had the time to get to because of school. I've finally finished that entire to do list with the exception of my no start issue. I really need help figuring out what's wrong without spending 1000's of dollars on parts roulette.
That being said, I am highly confident the battery is not the issue. I am on my third battery now (the last two didn't fix the issue either) and I tested it to make sure it holds a charge when unplugged for a couple days. I haven't ruled out the possibility of the alternator being bad but the voltage across the alternator when idle is about 14.4 volts so I'm pretty sure the alternator is working well too. The battery sits at around 12.6 volts when it isn't connected.
The past two winters I've only had issues with no starts when it was colder out (<20° ), but this spring it wont even start at 50° without the jump pack giving the system a boosted voltage. I tried the heat gun on the ECM trick when its cold and it did nothing unfortunately. I thought it had something to do with heat because when the engine is at full heat the truck will sometimes start correctly if I do it immediately after turning it off, but more than 5 mins and I have to jump it again to start it.
I even measured for parasitic draw and found it was only 90 milliamps which I should still look into but shouldn't be making my truck require a jump pack every time it needs to start.
When I try to start it, I just get really hard cranking/movement of the pistons that sounds like its just about to turn over but it never does. Some guy said it could be my fuel pump and admittedly my car sounds just like this video @ 0:25 :
but I don't understand how it could be the fuel pump if the car has no issues once I use the jump pack to start it.
Recently it got to -4° where I am and I couldn't even get it to start with the jump pack. The battery was dead (presumably from the parasitic draw) and the starter just clicked and then my gauges fluttered a bunch. I've look at pretty much every thread on here that some what resembles what my issue could be and I'm still almost at a loss. At this point I've looked at possibly just getting the two cam sensors and the crank sensor replaced, replacing the starter and the fuel pump, and if that doesn't do it then move onto something like flagship one and have them ship me a preprogrammed ECM. If the ECM doesn't fix it maybe its in the IPDS? So there are so many possibilities and nothing that's really sticking out to me as being the absolute issue and that's why I'd really love some of this boards experience and I'm willing to test whatever you guys think of.
-Gets a spark
-Has fuel pressure
-battery is good
