1 - 7 of 7 Posts
Got my front bumper to about 95% complete. Still have touch up to do and splatter to clean up. I'm thinking about putting a layer of rattle can paint on it until the weather warms up for a better paint.
My passenger frame horn has a slight twist it. The car was supposed to be accident free. Who knows? It was enough to drive me nuts. Stuff just wouldn't line up right. In the end, I left a couple things off just to finish up.
132812
I like your off road light setup on roof. im also thinking of similar setup for my X
can you please share the how is the light bracket fix into the roof and what lights your running, Any suggestion will be much appreciated.
Thanks.
Looks good to me :)
This is the first attempt. Once I finish a few other projects, I am going to scrap this one and make a new one. I am not a fan of the lights being so far forward.
To attach it, take out the first two screws of the air damn on each side. I should echo what has said many times before. Purchase a rivnut gun in advance and make sure it comes with M6 rivnuts.
I picked up these lights off Amazon. They are a flood/spot combo. I find them to be more flood than spot. I use them at work more than anything, and they do produce a good working light.
I used a cable gland to go through the roof. My car came with satellite radio. I used that hole to run the wire. I did use 100% silicone on the gasket and on the wire where it goes through the gland. It rains alot here, and I didn't want to take chances.
132848
Bumper is getting closer to finished. Still have to wait for warmer weather for the finish coat.
133210
Finally got around to getting the bumper painted. It's going back on the xterra tomorrow
135696
1 - 7 of 7 Posts
