Dual Batt Mod Engine Compartment ~ COMPLETE Pictoral Install Feb-2-2013 (REDONE)
46365 Views 136 Replies 55 Participants Last post by  cvillfarms
More pics tomorrow when Jeff of Arabia's overkill downloads them to a stick for me. :):)
The pics will be more informative then tonight's posting.
He plans to give his write up to Kodiak industries http://kodiakinc.com/powersystems/dualbatterykits.html for a kit to be made and sold.
this was a one off using an existing kit. and modifying it. The great thing about this approach is that it uses as many existing holes and nut mounting points that already exist as possible with very little fabrication.
Note relocation of Power steering reservoir
These were PC1200's
PC 1200 Specs:
* 1200 cranking amps for 5 seconds
* 1090 cranking amps for 10 seconds
* 900 cranking amps for 20 seconds
* Short circuit current over 2600A
* 44 amp hours
* 78 minute reserve capacity with 25amp load
* Female brass terminal w/M6 SS bolt
* No metal jacket
* Length 7 11/16"
* Width 6.5"
* Height 6 5/8"
* Weighs 37.5 lbs
some switch shots.
Cable run and fuse to the back of the rig for the secondary winch
1 - 20 of 137 Posts
nice work! i plan on doing this this coming spring. I will be dropping another die-hard plat in my rig! CHRISHAMMEREDUSA FTW!
Nice work, guys. Looks like Kodiak already has an Xterra kit listed on the bottom of their website home page. Wonder if they mean 1st gen or if they've already listed it in anticipation of a quick turnaround on a 2nd gen kit...
How much was this setup with the bats?
The one listed is for 1st Gen Xterra's.
The second Gen has not been built yet.
My one off uses a Jeep pre-built tray from Kodiak and is re-purposed for us.
This should speed things up since the rest of the kit is already built and we just need the write up and a few brackets for the relocation of the Power steering reservoir and the side wiring.
More pics showing the complete fab coming in about an hour. :)
This is pretty sweet. Id buy this kit.........Then pay someone to do the work.
Complete Pictoral install NEW PICS UP
see first post
That's what I did Mark.
Only the kit price will be cheaper than I paid for the R&D phase of extra man hours.
around 1500 and change (for me)
Im just totally afraid/against doing any electrical work on my Xterra. Thats one thing you can royally screw up if you dont know what you are doing!
Can you use and two batteries? Providing they fit that is.
Here is the instructions.
the batts go like this:...........
MODE 1
batt 1 and batt 2 get charged every day, isolated when power off (green light position)
MODE 2
only main batt starts vehicle, only main batt charged only powers accessories on main
isolate both batteries when off road. Total disconnect aux batt from main batt (center position)
MODE 3
emergency
Connect both batts together with ignition off or on
Joins batts for starting or winching or when main batt is dead
Note : select mode 1 after use of MODE 3
some switch shots.
Me likey! This will defenetly be on my long term wish list as I don't have a real need for a dual battery setup right now but I have plans to change that in the future.
Excellent Job! Definitely a better way to go than my setup. But its pricey
I am guessing in the 8-9 hundred bones range.(with batteries)
Note: this is pure speculation :):)
^did you get it free or just haven't seen the bill yet?
This is a great mod. Id like to tackle it myself this summer (since im an electrical engineer). I should be pretty straightforward. I am planning on using an electrical controller/monitor to manage and display the power in each of the batteries....and ill be hooking up the whole system to solar panels on the roof for trickle charging while camping. Good work again chris.
that is a great idea, however will you have to spend extra coin to get ones that aren't going to crack with hail/rain/etc?
Well done!
Great design, great batteries ;), great execution and nice post!
If I ever need to go dual battery, I will surely reference this post. :eek:ccasion5:
1 - 20 of 137 Posts
