1 - 4 of 4 Posts
Hey guys, I'm going to be doing a body lift tomorrow and have a question about the coolant. I'll have to replace the upper radiator hose because I don't plan on dropping the radiator. So, can I just drain the coolant enough to be able to take the upper hose off and refill, or is that a bad thing. I ask because I just had my coolant flushed and filled a couple months ago. I have two 50/50 gallons of the Nissan Blue stuff, I just figure it would go quicker.
I've looked up rook's and snoborderphx's guides and I'm not entirely sure why the lower hose needs to be disconnected at all.
Thanks!
just take off the upper hose and replace with the new hose. You'll lose about a pint of coolant. The instructions are half retarded and have you doing stupid stuff like disconnecting your steering from the rack and pinion shaft
Sounds like a plan to me, that's about what I had in mind even though it'll make a little mess. I know about the steering rack thing, mostly because I had my steering rack replaced under warranty a few months ago, so I know where the adjustment points are.
Thanks for the quick response too!
the bottom of the radiator has a plastic Phillips drain plug.... I would drain radiator into a home depot bucket..... but from my personal issues.... only 1 time I was able to turn the plastic screw thing... the last time I tried it began to strip it self to pieces so I stopped and disconnected the bottom radiator hose.
1 - 4 of 4 Posts
