1 - 12 of 12 Posts
Is there any way to disable the auto rolldown feature on the driver's window? Can't stand it....
You should be able to roll it down incrementally if you dont jam it down. If im not mistaken there are 2 down positions.
Yes I know, but they're on the same switch. I just want to get rid of that feature if there's a way to do it. Personally I don't need or want it.
Hey KnightRider what part of SD are you in? I have a '12 also, I'm in IB...
Cram something in the switch so you cant press it down all the way.
On our Subaru, disconnecting the battery deprogrammed the auto-down (and I finally found a way to re-program it.
I don't know about the X, but maybe that's worth a try. HPH
I hate the auto roll down thing also. If I wanted the window all the way down I would hold the button. I assume there is a second pin on that switch. I have always meant to pull the door panel and figure out which it was, and just snip the wire. If you ever figure it out let me know.
1 - 12 of 12 Posts
