1 - 9 of 9 Posts
· Registered
Hey guys, new to the forum. I recently picked up this 12' pro-4x model. I didn't look thoroughly enough for corrosion - mostly checked the frame and neglected to really crawl under there. Anyway, this diff cover is looking really rough. Doesn't appear to be leaking and feels solid but wondering if I should swap it out? Is that an easy thing to do? I wanna change the gear oil anyway. I looked on RockAuto and they have replacement covers but not 100% sure which one is right.
Wheel Tire Automotive tire Vehicle Tread
· Registered
Yes it is easy to do. You can wire wheel it and put some rust converter on it like POR-15. I elected to buy an ARB iron cover for mine. You should also do the diff breather mod while you are under there to prevent blown out axle seals.
· Registered
2011 Pro 4X,Night Armor.
It's easy if the bolts break loose without snapping. Mine looked like that too. Spray some PB Blaster on them a for a few days before doing it. I also took off the lower sway bar bolt on the right side in that photo and loosened the top one so I could move it out of the way a bit.
I also moved that brake line across the top of it by removing the bolt on that left bracket.
I used this instead of messing with RTV sealant.
· Registered
Cool. I'm not sure which cover works for me - is it this one?
1 - 9 of 9 Posts
