1 - 10 of 10 Posts
Guys had a question on what you have used to put plastic decals back on the X. i am planning on taking the PRO4X/Xterra Logos off and hitting them up with some Satin spraypaint.... Getting them off is easy with a heat gun/dental floss/goo gone...but what did you use to put them back on? I dont want it to damage the clear coat if I ever have to remove them again due to fading. My usual 3M tape wont work unless they sell them the same dimensions as my logos...which is doubtful :)
Part number / Manufacturer is appreciated...Thx
Cool thanks, i assume you use a razor blade to cut away the excess when your done? Taping off the area around the logos due to the lettering/shapes seems like it wouldnt work that well.
Adding to this. Anyone looking to do anything to emblems should think about plastidip. Saves a ton of time and isn't messy, and they have a ton of colors.
Gun metal on Pro-4X Black with glossifier on the burger
When I did the burger I put 2 small pieces of tape inside the ring to start pulling out the overspray.
1 - 10 of 10 Posts
