Here are my BFG AT KO 285/75 and one pro comp Xterrain 285/75
OK I will bite. Why only one pro comp?S_e_X-Terra said:Here are my BFG AT KO 285/75 and one pro comp Xterrain 285/75
Except for the fact that the ProComp is a directional tire, so it can only technically be used as a spare for 1 side of your truck, you'd need another one mounted the other way for the opposite side.....This is only technically speaking of course, I suppose it wouldn’t be too bad if you just use it for emergencies.S_e_X-Terra said:...the Pro comp is my spare. If i ever get a flat or something the spare will only be for driving me to change or fix the tire... then the spare goes back up top. I just liked the way the Pro comp looks when its up in my rack so i got it. Ya get it?[/b]
stevet47 said:Except for the fact that the ProComp is a directional tire, so it can only technically be used as a spare for 1 side of your truck, you'd need another one mounted the other way for the opposite side.....This is only technically speaking of course, I suppose it wouldn’t be too bad if you just use it for emergencies.
