1 - 4 of 4 Posts
I searched around for a bit (<10min admittedly) for exhaust specs on our trucks.
I am about to ditch the Y pipe and do the 2 into 1 muffler. Need to run out and get some mandrel bends and straight pipe and thought i would touch base on here for diameter and lengths before crawling under the truck with a mic on a hot ass day just to make the measurements that i know a hundred people here have done.
Also;
I have been thinking running two 45* mandrels for a smoother transition. Any advice or just get the one 90* and call it good?
still flipping a coin on bumping diameter up. It's a lot more work for not having a thoroughly engineered exhaust. If i build too big too fast i'll lose all back pressure and sacrifice torque. At the same time, if i just do one step up somewhere early and keep it simple it may help since it is pretty pea shooter exhaust.
Ideas and opinions appreciated
Exhaust diameter.
Aside from that recommendations on setup. 2x45* for smooth transition or just get the 90*. Make a Y pipe or just run the 2 in 1 out muffler. Pictures of setups, i have only seen 1 fairly small not too great pic of setup.
I know what i want but just looking for some ideas or opinions before i pull the trigger.
1 - 4 of 4 Posts
