Even after greasing the hood latch?Bueller44 said:I know about the hood squeek, never have been able to get rid of that, it pisses me off.
Does it happen when the windows are about halfway down? Mine did that and I took it to the dealer. I read that there was a TSB on it, although I'm not sure it was actually on the X. They replaced the window regulators and it seems to have stopped, although it's been cold so I haven't had my window's open muchshane.kelly55 said:i'm having the same thing. i have a brand new S 4x4 and both the driver side and passenger side front door/window have a rattle. It sounds like two telegraph's talking to each other.
I had it into thr dealer in Irving Texas and they put in some foam shims. The driver's side seems better but the passenger side is still bad.
It seems like its coming from the partition between the front and rear windows where the seat belt comes from. I have searched everywhere for it but no luck.
Anyone having the same issue?
cheers...
shane
Well, I don't know what you mean by "a wicked noise like that", but if it's a squeak, and coming from the rear hatch, it may be a loose clip on the door's interior trim. My Lift Gate Leak thread shows where the clips are located. With the gate open, you should be able to tell if any of them are loose.XterraXtian said:I have a wicked noise like that, but in my back door. I thought it was the rear wiper. But I don't think so. It even does it when I shut it. It drives me insane. Especially over bumps.
Thank you....yes, roughly translated "wicked noise like that" from someone from MA, means a "squeak" to everyone else. :laughing6:dpatton said:Well, I don't know what you mean by "a wicked noise like that", but if it's a squeak, and coming from the rear hatch, it may be a loose clip on the door's interior trim. My Lift Gate Leak thread shows where the clips are located. With the gate open, you should be able to tell if any of them are loose.XterraXtian said:I have a wicked noise like that, but in my back door. I thought it was the rear wiper. But I don't think so. It even does it when I shut it. It drives me insane. Especially over bumps.
tail gate drops in cold weatherXterraXtian said:Also, you you have trouble with the hydraulics (on the rear door) whe it's cold?
