Am, or rather, was re-installing after putting in a new radiator. I snapped one of the four bolts that hold the cooling fan in.
The FSM says that the bolts that hold the cooling fan on to the fan coupling should be tighten to 78 ft-lb.
I tried it at much less with torque wrench, starting at 40 ft-lb.
Questions:
1. Am I interpreting the FSM correctly? Here is the relevant diagram from CO-18. (2006 AT OR)
N.m (kg-m, ft-lb)
78 ft-lb would much tighter than what I encountered removing the fan.
2. Can I run the X with one fan bolt snapped? Or should I immediately remove and replace?
3. How do I remove the Fan coupling? Or better yet, what is the best way to remove the Fan coupling? Once removed, it would be relatively easy to drill out the snapped bolt.
God, I feel like a dumbass......
Questions:
N.m (kg-m, ft-lb)
