1 - 19 of 19 Posts
I've been searching all over and I'm sorry I don't know the difference between the C200 and the M226. I have the 4wd version of the 2006 Xterra.
Can someone confirm whether I use 75W-90 or 75W-140 in the rear diff?
And it looks like regardless of the model the front is 80W-90.
Thanks!
Is your S model an automatic, or manual trans? If its an auto, you have a C200 rear diff. If its a manual, you have an M226 rear diff. Fluid type and capacity for both are in the Sticky at the top of the powertrain section titled "Reccomended Fluids and Capacities". Here is a link to it: http://www.thenewx.org/forum/showthread.php?t=3912
Sorry, it's an automatic. I read the sticky and it was confusing, still didn't seem to say with 100% certainty what it was that I needed for the rear diff, just listed the two types. Thanks!
So you have a C200. You need:
Rear Diff:
C200
Type: API GL-5 Synthetic 75W-90 Gear Oil or Equivalent
Capacity: 3 3/8 pt or 1.6L
And for front:
Front Dif (Xterra R180):
Type: API GL-5 SAE 80W-90 Gear Oil or Equivalent
Capacity: 1 3/4 pt or .85L
Veteran - AKA Truffle's
Rear Diff:
C200
And for front:
Dont for get the crush washers
yes, two for the front and one for the rear!! Use rtv grey for the rear fill plug.
I seem to remember that it's all the same washer/part number too.
just did my c200 front rear and tcase. 75/90 back, 80/90 front. its pretty straight forward, lots of DIY's in this forum.
Rear Diff Oil Type
I just checked the owner's manual of my 2011 P4X Auto and it indicated that I need 1.6 liters of the 75W-90 oil for the rear diff. Why is this different than what I read on this site? I hear everyone else is putting in the 75W-140.:withstupid:
This is how I interpret it since the manual transmission xterra has an m226 and the line that specifies 75w140 is on the same line with the M/T spec.
I keep all the service manuals and the owner's manual saved to my phone just in case. I highlighted why I think most use 75w140
(sometimes having a galaxy note 4 is useful)
Nissan changed the spec on the Xterra M226 for Model Years 2009-2011 (they went to 75W-90), and then changed back to 75W-140 in Model Year 2012 and going forward.
Here is a thread on the M226 fluid recommendations by Model Year:
http://www.thenewx.org/forum/showthread.php?t=48221&highlight=M226
FWIW, I have asked to have the mods update the recommended fluids and capacities, but that hasn't happened yet.
Super Moderator
Does Nissan sell the crush nuts or can you use RTV?
Personally, I would want nothing to do with crushed nuts.
If you are referring to the crush washers, they are available at NAPA, O'Reilly Auto Parts, and I would presume nearly every good auto parts store. (I purchased at NAPA.)
My preference is not to use RTV as a thread sealer when the FSM calls for a crush washer.
1 - 19 of 19 Posts
