1 - 14 of 14 Posts
Just wrapped up installing TGC front spacer and Deavers AAL from PRG.
It took about 2hrs for the front and 3 hrs for the rear to do. I did not tak any Pics during the process as much better picture takers have that covered. I have one pic i just took after the fact. Finished just in time as that is snow you see starting in the background. it is already about two inches in an hour and a half. Time to go play.
Looks good dude!
Rob
Looks good synjohn!! I am actually down in Tukwilla for the weekend. Doing some Xmas shopping. Was hoping it would snow a bit more. It barely stuck here!!
Fronts were 34 1/2" now 37". and the rear was 34 3/4 now at 37 1/2". Is this what you ended up with.
I also have the 10 ply BFG wth the black sidewall that BFG site says is .2 inches larger than white sidewall of the same size. Very Strange.
sorry bout that. Yes I did measure from ground. Center of tire to fender is 21 3/4 front and 22 rear.
SWEEET!
is she 2wd?
4 x 4. Will change sig.
Discussion Starter · #10 ·
1 - 14 of 14 Posts
