1 - 4 of 4 Posts
so i installed coil spacers for my front lift kit, i did not install the new camber bolts. my tires are wearing badly on the outsides but only in front. if i installed the new camber bolts and got and alignment would this fix this or would a better idea be to just buy the new coil overs and ucas?
Whenever you install a lift you need an alignment. An alignment should be on the list for any front end work actually, including just replacing worn components.
Camber bolts will help get the truck to a better spec, not just "in range", so I would buy them.
Rotate your tires, if they aren't completely fubar on the outside placing them in the rear may help even out the wear somewhat.
1 - 4 of 4 Posts
