Would like some clarification on coil lift.
Understandably, the coil lift does not add travel. With its higher spring rate and the reduction in sag, lift is obtained. The suspension stroke is now starting with shock in a more extended position. Questions:
1) With suspension settled on flat ground, what is the clearance between the UCA and top coil bucket? (This would be the max possible increase in shock length w/o changing UCA's.)
2) Would longer shocks close that gap and offer a bit more lift?
3) For those running longer shocks (off other applications like pathfinders), does your shock limit the down travel, or are you now seeing contact between the UCA and coil bucket like those with spacers? If not contact, what are the longer shock PN's and dimensions (extended and compressed)?
4) Has anyone tried fitting a spacer just shorter than the clearance to maximize lift (although this would nearly eliminate any room for droop)?
5) Are springs so stiff as to not allow full compression? (which actually decreases the amount of usuable travel) I believe the answer is "no", but wanted clarification.
Thanks for any feedback from those with coil lift and/or longer shocks.
