More info on the camber bolts please! I had the AC coils and AAL instaled and there seems to be a little extra negative camber on the front. Is this what others have experienced? I was hoping that the rig would settle and that extra -cam would go away.
btw - the extra stiff springs are sweet on the X. Most of the squat and dive has gone away as well as a lot of the roll. I'm glad i got the AAL. The stiffer spring rate in the rear seems to have reduced some of the skitter when you drive over bumps on a curve at highway speeds. I thought the oposite would happen. :bounce:
With this set up my OR model was lifted 2" front and 1 3/4" rear, but i did the measurements after adding a full set of Shrockworks skids and sliders, oops.
