1 - 18 of 18 Posts
Intro Comments: I have always liked the Xterra, and since buying one 3 years ago I have spent lots and lots of money thanks the people here. But the plan is to build a overland vehicle. About time I make a build thread.
Username: cjs83
Year: 2010
Trim: SE
Color: Red Brick
Mileage: 41,XXX
Electrical:
Blue Sea fuse Block 5026
Die Hard Platinum Battery
ARB CKMA12 Air Compressor W/ pump up kit
Hella Supertone Horns
Wheels:
265/75/16 BFG A/T KO's in the garage and off the X
285/75/17 Toyo Open Country A/T II Now on the X
OR Rims in the garage
KMC XD Series Rims flat black 17" Now on the X
Bora 1.25" wheel spacers
Weather Tec floor liners front/Rear
Xterra rear carpet rug, slits cut for utilitrack/ 2 sets of cleats
Frontier 5 Switch 4x4 panel
Mini 0806 Dash Cam
Raingler Gate Pocket
Shrock Works Front bumper
Warn m-8000s Winch
Shrock Works Rock Sliders/w dual supports
Shrock Works Fairlead
Shrock Works Flip up license plate holder
Maxterra Rear Bumper/Tire Carrier/Hi Lift/CB Tab/Backup lights
Matching spare rim/tire on tire carrier
Viggs Hood Black Out (needs to be redone)
Nissan Hood Visor
Nissan rear tail light guards
all 4 window vents (weathertec)
Southco Locking wetbox handle
Stubby Antenna
Boulder Iron works Shock Skids
Hefty Fab Steel Engine Skid
'05 Front Grill
Tinted front windows
OR body side Moldings
16" rear wiper with stiffer spring
Radlfo Extended Travel Coilovers 650lb springs
Extended Coilover studs
M14 Lower Shock Bolt
Nisstec 1" top plate spacer
PRG Rev2 upper control Arms
PRG Camber Bolts
Alcan Leaf Pack set at 2" with 300lbs over stock
PRG Shackles currently set at lowest setting
Bilstein Rear 5125 Shocks model 6253
PRG U Bolt Flip Kit
Nisstec Extended Brake Lines (all 4)
Updated Front Sway bar bushings
Rear sway bar removed
Driveline:
M226 Swap with ARB RD149 Locker 3.54 Gears
R180 w/ARB RD181 locker 3.54 Gears
ARB Diff Cover
Tom Woods Double Cardan Drive Shaft
Engine:
Volant 12740 CAI
AEM 21-209EDK Dry flow filter
XTP IMS
Magnaflo 12580 Muffler Y-Pipe Delete
Marine Brass +terminal
Lighting:
20" SR light bar on front bumper
Morimoto LED fog lights in the Shrock Bumper
Projector Headlight Retrofit/ W halo's and Devil Eyes
Backup lights in the maxterra bumper
VLED LED corner lights
LED Backup Lights got them from Maxterra
Future Plans:
waiting on Steevo to make 4.10's for the R180 :)
DepHep or Gobi roof Rack?
XD series Addicts wheels 17"
Bedline some stuff
Hefty Steel Tranny skid
Hefty Aluminum transfer/gas skid
RCV Axles?
maybe a tire carrier with gas can holder.
Bully Dog GT Tuner.
Custom CB install
Not current but here are a few. I will post current pics soon.
Completely Stock not much after I bought it...
Bumpers and headlights
Comments: After a few set backs with the m226 swap everything should be good to go now, just waiting on it to get all put back together. Big Thanks to Iron Rock offroad for doing the M226 swap and lockers and gears, was the first Xterra they worked on.
Awesome! I've been eyeing 285/17r17's for a few years now :)
Those Toyos I have are pretty awesome, its a pretty big difference from the 265's that were on there before. I had to Trim about an inch off the fenders to get them to not rub, Although I am still slightly rubbing on the driver side but its just the fender liner, I think a little more melting should take care of it.
Here are the updated pics. Enjoy :) by the way I am horrible at taking pics
Tom Woods DS, magnaflow muffler
Frontier switch Panel
Mini 0806 Dash Cam
Volant and Air compressor
Hella Supertones behind the Grill
And The M226:rockin:
I still need to go over the fender trimming with touch up paint but it actually turned out pretty good, it didn't chip the paint like I thought it would, there is one spot that the dremmel slipped and it gouged the paint a little, I had painters tape on and it helped a lot. I also need to melt the liners back a little more.
Mini 0806 Dash Cam
Looks good. How do you like the tires? Have you used them in any mud yet?
Good looking truck. I wish I was still up there to see it in person.
Beautiful rig!
I like your ARB OBA install and plan to get one for the same purpose. It looks like its mounted to your Volant tube?
Discussion Starter · #17 · (Edited)
the Compressor itself is bolted to the side of the Air Box and is a perfect fit, the pump up kit is also a good fit in its location, I was originally going to have it aim straight up but it was super close to hitting the hood, so I just aimed it to the side.
Discussion Starter · #18 ·
so yesterday I ran 1/4" nylon split wire loom over the entire length of the rear air line to give it a little extra protection. I didn't bother doing the front locker air line because I plan on upgrading that entire air line.
1 - 18 of 18 Posts
