1 - 20 of 21 Posts
isn't the housing red? so using the basic principle of the RBG color scheme, if you use a blue or green bulb, you can get purple or yellow colors...right??
it might work, but in all seriousness, if you want another color likely you'll have to change the light housing since it is red.
Parking lights are to be amber in color only per DOT regulations. Easy to fix for state inspections, but thats just another thing for a cop to get you for. Just a heads up....
i wanna see tht, do u have a pic?
dont try to take it yourself while its in reverse, thatll be a disaster.
Are you changing just the rear or the fronts too? I replaced the front parking lights with white LEDs. I eventually put white LEDs into the big round one too after this pic was taken.
1 - 20 of 21 Posts
